It's sad not to see it in the official release :(
Is there anything it can be done to include it?
In any case, Thaaaank you very much for the info.
Catalan translation
I'm not quite sure what Zenju's criteria are for integrating languages is. The problem I can see is that is has to be constantly maintained as text is added/removed. I don't know how he is doing it for the other languages, but it would be a huge amount of work manually
Hi FreeFileSync Team,
FFS translated into Catalan for version 11.14
Attached below catalan.lng file in a RAR.
Thanks and enjoy!
Thanks and enjoy!
- catalan11-14.7z
- Translation for FFS v11.14
- (14.27 KiB) Downloaded 1629 times
Thanks xCSxXenonYou're awesome for keeping up with this! xCSxXenon, 30 Jan 2021, 21:57
I like to have GUI in my language.
It also encourages me to see the number of downloads.
FFS translated into Catalan for version 12.0
Attached below catalan.lng file in a 7z.
Thanks and enjoy!
Thanks and enjoy!
- catalan12.7z
- Translation for FFS v12.0
- (14.72 KiB) Downloaded 1193 times
FFS translated into Catalan for version 12.1
Thanks and enjoy!
Thanks and enjoy!
- catalan12-1.7z
- Translation for FFS v12.1
- (14.73 KiB) Downloaded 1135 times
Send the flag file and the Catalan translation.
good luck
good luck
- flag_catalonia.png (207 Bytes) Viewed 22354 times
I don't understand why Catalan is not in the program.
If pull requests were enabled in github it would already be done.
I translated some open source projects to Catalan language and it's so easy.
Regards.
Regards.
RAR file is not considered a convenient archive format since it need additional software like 7-zip to extract the files, unlike zip which is natively supported since Windows MEHi,
Why the application does not show Catalan as language if it is translated?
Flag of Catalonia (if there is any doubt): https://en.wikipedia.org/wiki/Senyera
Thank you in advance Rincewind, 19 Mar 2021, 20:58
If the problem is the extension, I attach you the zip file.
Regards.
Regards.
RAR file is not considered a convenient archive format since it need additional software like 7-zip to extract the files, unlike zip which is natively supported since Windows ME harryytm, 24 Jan 2024, 05:13Hi,
- catalan12-1.zip
- (15.17 KiB) Downloaded 594 times
