There is a problem with the synchronization selection menu in 9.7 (and 9.6, 9.5... it does not matter what language you use).
There is no option to select in "Run a command after synchronization"
SO: Ubuntu 16.04.3 LTS x64
FreeFileSync_9.7_Ubuntu_16.04_64-bit.tar.gz
FreeFileSync_9.6_Ubuntu_16.04_64-bit.tar.gz
FreeFileSync_9.5_Ubuntu_16.04_64-bit.tar.gz .... (maybe many more old versions)
This does not happen with the PPA version 9.0 (ppa:eugenesan/ppa)
problem with menu "Run a command after synchronization"
