file path length limitation on Mac OS X? "Error Code 5: Input/output error (readdir_r)"
onlinespending
I'm trying to use FFS to sync files between my MacBook and a local SMB share, but I'm experiencing an issue when comparing files that I suspect has something to do with the file path length. Is there a way to workaround this limitation? They're both HFS+ partitions.
Cannot enumerate directory "/Volumes/Ken/Synced/Investing/Historical Data/data-6/daily/macro/us".
