[BUG] Portable installation is broken in v8.0
ayuanx
FreeFileSync - An exception occurred
Installation files are corrupt. Please reinstall FreeFileSync.
Cannot open file "B:\abc\install.dat".
Error Code 2: The system cannot find the file specified. (CreateFile)
OK
grad
I'm getting a similar error. I have FreeFileSync portable installation installed into the Dropbox folder. On the computer it was 'installed' on it works fine, but on another computer Dropbox syncs to, I'm getting the following error when starting the application:
Consistency check failed for "C:\Dropbox\FreeFileSync\install.dat".
OK
smaragdus
The same error here, please see the screen-shot:
I have been using FreeFileSync for years and I get such an error for the first time. I am going back to FreeFileSync version 7.9 which runs fine. I hope the problem will be fixed soon.
radek
Added in version 8.0, among others:
"Automatically check consistency of FreeFileSync installation".
This is related to the installation consistency checks that are now included. FreeFileSync will test during startup if any data corruption occured to the installed files.
Portable usage should still continue to work if you install on an USB stick directly and move it between different computers, or if you move it to the USB stick manually via Explorer. But it may not work if the copying is done via Dropbox, in which case it needs to be installed on the other PC, too (either locally or portably).
Seb_lau
I've just reverted as well, having had the same issue using SyncThing.
This was a very stupid "feature" to make mandatory (no option to disable or continue despite this check?)
The whole point of using portable installs (for me) is so I DON'T have to manually install/copy/move a USB for every machine..
ayuanx
Portable usage should still continue to work if you install on an USB stick directly and move it between different computers, or if you move it to the USB stick manually via Explorer. But it may not work if the copying is done via Dropbox, in which case it needs to be installed on the other PC, too (either locally or portably).Zenju
No, unfortunately that's not the case here.
Any fresh installation selecting portable checkbox won't have "install.dat" file.
You may test it yourself. (Make sure you don't have any existing installation on the computer).
radek
Meaning we can only make a portable installation 1) on a USB drive and and 2) only if it's not installed on the hard drive?
You may test it yourself. (Make sure you don't have any existing installation on the computer).ayuanx
When you close the FFS installation dialog, the file will be created (irrespective of portable/local installation type).
ayuanx
When you close the FFS installation dialog, the file will be created (irrespective of portable/local installation type).Zenju
Come on, we are not idiots.
You just secretly updated the installation file a minute ago and refuse to admit it.
You think no one will notice but you forget that other sites have fetched the file before your secret update.
‎Original signing time: Wednesday, ‎16 ‎March, ‎2016 07:09:32
Updated signing time: ‎Friday, ‎18 ‎March, ‎2016 06:49:22
ayuanx
Just for the record, I don't know what you are trying to hide, but apparently you secretly added some code to record (or collect?) user's information. What exactly it is for, we have no idea yet.
Because for this part of the code, you deliberately hid it and did not put into the source code you provided.
I suppose 99.99% of people won't notice since few people would bother to read the source code.
I reckon I wouldn't normally, but this time you made me do that.
I am aware you might secretly change the source code file again.
FreeFileSync_8.0_Source.zip 2.83 MB (2,976,767 bytes)
I hope you intentions are good.
zlhnxqgf
Because for this part of the code, you deliberately hid it and did not put into the source code you provided.ayuanx
Can you provide some details? I would like to check it myself.
Are you serious? Why do you want to ruin your reputation with such changes?
updated the installation file a minute ago and refuse to admit it.ayuanx
record (or collect?) user's informationayuanx
Jesus, ayuanx... yes, the 8.0 release was updated (twice!) to fix small showstopper bugs during the installation. These bugfixes don't affect users who have already installed 8.0 with success, so there is no need for a 8.1 update. Why these trivial upates make you throw wild accusations is beyone me. Please don't troll and keep the discussion based on facts.
ayuanx
Jesus, ayuanx... yes, the 8.0 release was updated (twice!) to fix small showstopper bugs during the installation. These bugfixes don't affect users who have already installed 8.0 with success, so there is no need for a 8.1 update. Why these trivial upates make you throw wild accusations is beyone me. Please don't troll and keep the discussion based on facts.Zenju
Like I said, I hope your intentions are good. But I couldn't find the part handling this "install.dat" in source code, which caused this installation failure in the first place.
This part is handled in the installer, which is not open source. As for the installation failure, is this still reproducible? If yes, I'd like to analyze what's going on.
ayuanx
This part is handled in the installer, which is not open source. As for the installation failure, is this still reproducible? If yes, I'd like to analyze what's going on.Zenju
No. The creation part could be in installer. But the read and verification part is in "FreeFileSync_XXX.exe".
I could read the assembly, but I don't want to spend time on it when there is supposed to be open source code ....
zlhnxqgf
But FFS complains if the file is missing or its consistency check fails so where to find these checks in the source code?
Would you please explain to us why you added them even though the portable usage is crippled now?
zlhnxqgf
No comment on the checks and source code? Are these questions inappropriate or just tiring?
ninj_marx4
FreeFileSync is a great tool no doubt but i have to agree with zlhnxqgf & ayuanx. If you want to keep your good reputation please keep things open source.
And the silent updating of a version is really annoying. Now there is a 3rd Version of 8.0 signed on 20 March. That's just confusing for everyone.
Hope you can fix this Zenju and still kudos for your great tool!
andreiv
I can confirm this issue. I keep FreeFileSync on my Dropbox and use it on 3 computers. It works on one of them (the one I installed it on) but it fails with the error mentioned here on the other 2.
As always, nothing is cast in stone, but the current 8.0 design is to only allow installations via the official installer with some leeway for the portable version. To clarify this, it's still possible to install FreeFileSync portably on an USB stick, carry it to another computer and use it there, or move it locally from one location to another. But it won't be possible to simply copy the files from one PC to another without an installation. This was done to leverage the importance of the FreeFileSync installer with it's single(!) and optional(!) advertisement, which is still the backbone of the project's financing.
I think I've also written this somewhere in the FAQs but with the number of users that FreeFileSync has, it has turned into something more than a hobby. So the time needed, not only for development, but also the tons of project management work done behind the covers, has to make at least some economical sense. Currently this means having the ad in the installer (but also donations; thanks so much to those who donated!) even despite the controversies about it (althout most of them originate from thinking principle rather than actual issues: come one, is clicking the decline button really that difficult?). As an alternative there now is also a version without advertisements for everyone who donates. Maybe this could be the best solution in the long run as everyone can choose for himself what FFS is worth to him, while avoiding the conundrum of coming up with a price for a tool that has *free* in its name...
I'm sorry for the silent bug-fixes, but these are a last resort in case of show-stopper bugs that only affect a small number of users. If they didn't affect only a small number of users it would naturally be resolved via a completely new release. If it wasn't a show-stopper bug, users could wait until the next update has arrived. But if the problem is a rare installer-bug as there were unfortunately a few with the 8.0 release, it doesn't make sense to have the majority of users reinstall when the issue doesn't concern them. Not fixing the bug is also bad since it leads to a lot of needless support requests about an issue already solved. It's a compromise for this particular case.
ninj_marx4
Thank you very much for your explanation! I accept your reasons and hope you keep up the good work!
zlhnxqgf
It all makes sense, thanks for the honest answer! I guess a clear statement on the ad-bundled setup would have been better in first place than just "Automatically check consistency of FreeFileSync installation" as a reason.
Too bad it's unusable as a portable app in cloud storage then, so I'll just stay with 7.9 for now.
FileHoarder
I have donated early on - and also recommended the software to others who told me they donated. Then had to cope with tons of aggravation because of your malicious practice to include crapware WITHOUT stating this up front - as other more honest developers usually do. This gave your product a very bad reputation over the many years you've been doing this.
So here are my questions:
- what is the minimum donation to qualify for the safe version?
- are previous donors not eligible for the safe version?
- for how many future updates does a donation guarantee access to the safe version?
zlhnxqgf
- for how many future updates does a donation guarantee access to the safe version?FileHoarder
will I need to make another donation every time I want to get a new version?Karia
Yes, you will have to donate again for the 8.0 release. But the good news is you can still choose the price yourself.Zenju
fred_be
I especially registered an account to say that
- I use FFS on a computer where I have limited OS permissions, and CANNOT run an installer.
- I typically install FFS update on my personal pc in portable mode, then move the files over to the target computer
I'd be disappointed if that is no longer possible.
I haven't tried 8.0 yet, but from this discussion, it sounds like this is no longer allowed usage. That would be a shame :-/
thanks very much for the useful software.
regards
ps: does the donate-no-ads version have the same restriction?
ektorbarajas
Hi.
I also use it the same way as fred_be
can this be fixed?
For now I have to stay with version 7.0
_svobodniy_
As always, nothing is fixed in stone, but the current 8.0 design is to only allow installations via the official installer with some leeway for the portable version. To clarify this, it's still possible to install FreeFileSync portably on an USB stick, carry it to another computer and use it there, or move it locally from one location to another. But it won't be possible to simply copy the files from one PC to another without an installation. This was done to leverage the importance of the FreeFileSync installer with it's single(!) and optional(!) advertisement, which is still the backbone of the project's financing.Zenju
- I typically install FFS update on my personal pc in portable mode, then move the files over to the target computerfred_be
I use it in the same way. So, I returned to FFS v7.9...
FileSyncExpert
I also changed back to Version 7.9
No more Updates with this Restrictions...
ektorbarajas
Will this annoying issue be fixed for version 8.1 ?
pblacky
sory folks, i did not understand englich so good!
as i understood it is possible to get an actual version without this installl.dat "feature" if i make another donation.
is this right?
or do i have to stay at 7.9 for using freefilesync portable ?
FileSyncExpert
The install.dat is Part of the New Version 8.0.
And the Donation is a good idea, so that all People who have been donated, have the Hope, me too, that the Installer comes in the near Future without any Crapware.
You must go back to Version 7.9, that comes without the install.dat Feature...
But keep up the good Work rocking and make a Donation...
We all hope that Version 8.1 comes without the install.dat...
zlhnxqgf
This rule will be relaxed again with 8.1 (release later today) to allow copying and using the portable version on systems other than the one where the installation occured and without having to install on a usb stick.Zenju
LiveFreeDead
I signed up to say I am also sticking with v7.9, if you choose to limit what the end user can do with your software by locking a file consistency check that checks the creation date of the file, just to make the portable version non distributable is wrong.
ninj_marx4
Version 8.1 is still affected from this limitation. Really sad :/
zlhnxqgf
Which limitation in 8.1 are you talking about?
LiveFreeDead
If you install FreeFileSync 8.0 or 8.1 as portable, compress it and then uncompress it to another computer/USB/HDD (either via dropbox or just carrying it on a backup USB then it will exit out with consistency error almost as soon as you run it. My understanding is that it forces more people to need to use the installer that comes with Ad ware (to make a few more $) more so than it protecting against modified .exe's as the damn .exe is already running when it does the check on itself, so it's pointless for that reason.
ninj_marx4
Which limitation in 8.1 are you talking about?zlhnxqgf
The install.dat problem which breaks portability although you quoted Zenju that it should be solved with v8.1. Strange.
zlhnxqgf
Works for me, you should probably be more specific about what doesn't work.
LiveFreeDead
This was me running it on a new PC after extracting my freshly zipped version of 8.1 Portable built on my other PC.
I then tried to remove the install.dat and got a missing install.dat error instead, meaning it doesn't act like v7.9 which I preferred as when I went to use 8.0 after a few weeks and a fresh OS install later I kept getting the error which was annoying as I ran it from a batch file that called 9 locations from a .ffs_batch file I made. I was trying to backup the family photos, so not fun to have errors showing up when I wasn't expecting them at such a crucial time.
FileSyncExpert
So, i make a Test of the New 8.1 Version!
Okay we have the install.dat again, but i removed the Portable Folder to another Destination on the same PC, and i have no Error on Start with the FFS Software. When i remove or delete the install.dat file on this Destination, i have an Error on Start.
In a few Hours i want to test the portable Folder on another PC.
When the Portable Version is correctly running, without the new install Process, the Problem with the install.dat File is no more existing. But it looks like that the install.dat file is necessary to run with Version 8.x, also with the Portable Versions....
But the install.dat File is for me a little bit suspiciously, and i want to use the Version 7.9 again...
FileSyncExpert
I test the Portable Version from 8.1 on another PC.
It works, but when i blocking the Access to the Internet via Firewall, the Potable Version doesn't work...
So my Conclusion to that: Back to Version 7.9
ektorbarajas
8.1 still has this annoying "feature" I installed it at my USB, then copied the whole folder to another laptop, and when trying to run the program the same message appears.
So this has not been fixed. I have to stay with 7.9. Hope this REALLY get fixed for next release
FileSyncExpert
@ektorbarajas
When your Laptop has no Access to the Internet, in this Moment, this is exactly what I also observed.
The install.dat "Feature" is not good for the Reputation of FFS...
ektorbarajas
Please fix FreeFileSync.
Fix that annoying install.dat issue.
NightOwl
@ektorbarajas
The install.dat "Feature" is not good for the Reputation of FFS...FileSyncExpert
i join FileSyncExpert and others, sticking with version 7.9
FFS is certainly one of the best, and maybe "the best", sync-program around, but the "install model" is damaging its reputation more and more step by step; fewer users will recommend it, while others simply can't or will use the software 'cause of scan alerts, etc.
of course, Zenju deserves a better compensation for his great work, but i think most of long time users will accept and prefer a paid commercial version (eventually besides a clean lesser-featured or trial version to promote the program) above the actual rather damaging model
FileSyncExpert
@NightOwl
I found no better Software for FileSync, and i tested many other Software over the Years.
A Commercial Version is the Best Solution for Power User.
