Flat versus tree file structure
... Everybody is used in everyday life to the green=OK, red=danger correspondence.JPringle, 25 Jul 2020, 12:32
This is culturally bound and certainly not universal. In some Asian countries the reverse applies. They are generally however aware of our western "bias".
Regarding the Purple vs Green background:
I like that you can instantly recognize the sync direction by the background color, without the need to look at the direction of the arrow.
And in either direction, still the "+" (plus) signs are green and the "-" (minus) signs red.
VladimirII
What I say is that there is no need to use green and purple to specify the right/left direction. What synchronization does is create, delete or update files so just highlighting right and left modified files is enough. And doing this by using the green and red, which are associated with OK/KO warning. JPringle, 26 Jul 2020, 14:31
It is, I´m very glad FFS is two coloured. Also that it has both sides in its view and not a single view as some other software shown here. That distinguishs FFS from other software.
You also wrote like red should replace purple ;)
Deletion is normal not a K.O. - what to improve highlighting nontheless -, discrepancies are problematic.
That FFS is not only a backup software also has everyone in mind?
JDB
Please just reinstall the old flat format. I tried version 11 and I can't decipher its meaning. I am back to 10.24 now.
Sonik_C
Please just reinstall the old flat format. I tried version 11 and I can't decipher its meaning. I am back to 10.24 now. JDB, 29 Jul 2020, 07:03
I'm also hoping we get an option to bring back the flat view. Not liking the tree view at all, to be honest. Tried both v10.25 and v11 and still not a fan of it. Flat view is just quicker and easier for me to compare.
If the flat view has been completely removed in all future versions, I will just have to stick with v10.24. I don't understand why we can't have the option to keep the old view though?
phhowe17
@Sonik_C
you can click on the headers to switch to the old view.
but even in v11, the horizontal spacing in the new view sucks. It really should be a fixed indent per directory level, not this offset to the end of the previous level's folder name.
Sonik_C
@Sonik_C
you can click on the headers to switch to the old view.phhowe17, 01 Aug 2020, 16:36
That doesn't really fully restore the old view though, as I like to see the paths. Unless I'm missing an option somewhere?
pooper
No, there are no other options (for the time being).
phhowe17 just keeps posting this answer, disregarding the fact that the paths are entirely missing...
Most users don't just like to see the paths, but have to see them!
JPringle
Deletion is normal not a K.O. - what to improve highlighting nontheless -, discrepancies are problematic. VladimirII, 27 Jul 2020, 09:40
Sorry, I misspoke: I didn't mean red as a color when FFS has a problem but when, through synchronization, the user can delete a file. Flashing it in red shows a warning, it's up to him to see if that's what he really wanted to do.
VladimirII
After working on other syncs with 10.24 I recognized a thing.
For log files, of installers or the FFS log, its crucial that it contains repetitive lines and characters.
Thus makes it possible to read the line even during scrolling or sometimes even jumping (PgDw/Up). Also to spot errors while scrolling.
The same applies in a kind to the Folder-Paths.
If every folder has only up to 10 files it does not realy apply.
If the most folders contain dozens of files, the folder name can be read during scrolling, if the filenames are consecutive they also.
With the tree view where only at on place the folder name is you have to spot it, stop, read it, maybe remember it - even it stays on most upper line.
For some or half this habit, to read while scrolling, is convenient. Tree view is taking this away.
Sorry Musenka you where not 'used' to this usage.
As already sad, tree view has it´s pro in a cleaner look and the possibility to save horizontal space (after more tweaking).
There is clearly a reason to have an option to choose between tree and full-line view.
bazbsg
I completely agree Vladimir11. My comment and request was to add a tree view (like WIndows, not like we have now in version 10.25) but to keep list view and to be able to toggle between them in real time, without having to repeat the compare stage. Having more than two views or options within the views is of course acceptable.
Musenka
I agree that both views (plain view and tree view) are both important and each of them is the best choice for some specific conditions. As I mentioned earlier, it's quite impossible to have one and only optionless view that is universally the best view for any use cases. These fundamental approaches (plain and tree structures) both deserve to be presented as optional views.
Additionally, at least for Tree View special "Save horizontal space" option would be very useful for the corresponding use cases. In "Save horizontal space" mode tabs corresponding to nesting levels should be minimized (but of course not omitted totally) and may be the first item in every separate folder should be listed not on the same line as path, but on the next separate line - with the same tab as all other contents of this folder (this saves horizontal space for the first item in any folder and provides more list uniformity).
As to me, I am still using version 10.25, because version 11.00 introduced bugs in visual representation (I described them in previous messages).
JDB
Flat view with a horizontal scrollbar is good. Why is it neccessary to fill the panels up with whitespace when there is a deep directory structure or long pathnames? When I view the results of a compare, I like to see where I am, not be left wondering in some esoteric cloudy white space.
JPringle
Also agree that the flat view or the tree view may be suitable.
So I take this opportunity to present my wish list:
- of course, first of choice between the flat view or the tree view...
- possibility to choose the background color in the lists (I would put on a green background the files that will be saved by the synchronization, on a red background those that will be deleted and on a white background what doesn't exist yet or will be updated)
- directory names could be written in bold for better readability
- reminder: the possibility to modify the icons already exists by modifying Icons.zip
I attach screenshots of what I mean:
FFS 10.24 with custom icons
Actual FFS 11
Possible custom version with flat view :
JPringle
Perhaps better if updated files are also on red background, as this version will no longer exists
VladimirII
If the Icon background colour stays the same as it is now your custom icons JPringle are not bad.
JPringle
If the Icon background colour stays the same as it is now your custom icons JPringle are not bad. VladimirII, 06 Aug 2020, 12:37
For a better experience, the icons background color could also be customizable :-)
JDB
I actually don't want to be able to customize anything. Let's not talk about aesthetics, colors, icons, and other things from the other side of our brains. Basic functionality is the main issue. Performing a comparison and seeing a bunch of white space with vertical lines, wondering where they lead to, or wondering which directory a filename belongs to, is NOT FUNCTIONAL. Move the theoretical discussions to another forum and talk here about actual use cases and operation. My use case is: I want to see the root location of all my files CLEARLY without having to apply some visual perceptual algorithm based on theories about trees.
thirl88
Well, JDB uses a lot of polite and clever words. Can I just be really straight to the point?
(1) I love FFS and have used it for years.
(2) The display of the grid in v11 is utter crap. Put it back the way it was. It wasn't broken.
SinusPi
My biggest gripe with the new "tree" display?
File 20 is clearly in "FOTO\2019". File 21 is... in "FOTO\!LRCAT"? Or maybe in "FOTO\2019\!LRCAT"?
Wait, wrong, both files are in the same folder!
Why fix what isn't broken? There are many ways to coll...pse paths that are too long, but this is absolutely not one of them.
JDB
@thirl88 -- thanks!
eclintATX
Please consider adding a button to switch between the tree view of the file structure and the older flat file structure. The descriptive nature of my folder names pushes the filenames off past the right of the windows. proehm3555, 19 Jun 2020, 20:08
I agree completely. This interface layout does not work for me.
Sonik_C
The tree view may look nice (with more tweaking) and keep the visual clutter of filenames/paths to a minimum, but it's counterproductive, for me anyway. With the flat view I can easily see on each line exactly where every file is placed. Tree view means that if I scroll down and the folder is off-screen, I have to keep placing my mouse over every file or scroll back up to see which folder it's placed in. When there are a lot of folders or files to scroll through, it just adds more time.
The flat view is one of the reasons I find this software so easy and quick to work with. I can see where everything is at a quick glance, without scrolling up or down trying to find the folder.
This forced change to tree view is not good imo. The amount of posts/views on this thread alone should be a clear indication of that.
The tree view just isn't as convenient as the flat view, for my usage anyway. Unless I can see the folder at a quick glance on every line without scrolling. I prefer functionality over aesthetics!
There was absolutely nothing wrong with how the flat view worked before. Just restore the option to keep the old view and everyone will be happy! This is a big change to the whole UI, which has stayed pretty consistent over the years. Giving users the choice would be the better option, rather than forcing the change.
I really don't want to have to stay on an older version without bug fixes, but it seems I might not have a choice if the flat view is permanently removed.
bgstack15
Zenju, please consider restoring the traditional file layout. The version 10.24 was the last one with a view where you could see the entire relative path or entire full path of the files. This view was the simplest to understand.
OmalleyTEC
I agree to the reviews of most of the other users posting here. I am sad about reading Zenjus post where he says that he doubts the need of options for this problem. :-(
But it fits to the fact that he rolls out a new version of his program without providing a beta version and without asking users what they want. I never saw any request. :-((
It is also fact that FFS is freeware and it is Zenjus project. He can roll out a new version an stop bugfixes and security patches for older versions at once. It is an ego software. Donations mean buying something without getting rights.
I can only decide if I want to use his software further on and if I will support it with donations.
I have to say that I don't like the way the developer handles the issue. But maybe I am the only one.
My decision for now is .... yes, I will use the version 10.24 until I found a better solution and ... no, I will not support it with donations until I get a version which is comfortable to me.
I will keep an eye on the project.
thirl88
Indeed, the developer has let himself down and let down all of those who have used his prgram for years and those who have kindly asked for the old functionality to (at least) be an option. Perhaps the developer has learned his update procedures from Microsoft as they are well versed in removing perfectly good and well loved features without warning!
In the main FFS has worked perfectly well (for my needs) for many years without ever needing to update, though I always update when there is a new version. But in recent times when I see the update notification I think "oh no, what has he changed this time"!
I too have gone back to 10.24. I'm not looking elsewhere for another program at this point. 10.24 does what I need without issues. It's a case of "it ain't broken, so I don't need to fix it". If that were the final version I'd be happy enough. For now, for me, it IS the final version. But I am very thankful for what has been created to this point. FFS remains my favourite file backup tool.
Don't crucify a developer for trying to improve the product. I highly doubt Zenju is running things with a "holier than thou" mindset. He does care about user feedback and has proven that many times over. Of course, there is nothing wrong with not liking certain changes, and options are great, but at the end of the day this is a passion project and I believe it shows. He may have let you down, but he has not let himself down, or me. I see changes toward a better future, which has growing pains sure, but may end up brighter at the other side. If your primary value is "it ain't broken, so I don't need to fix it", then you wouldn't/shouldn't have updated past the first version you got the job done with. I hope he continues working on the design, as I agree it can definitely be better, but it takes time.
thirl88
To be clear, I did not mean that Zenju has let anyone down (himself included) just because he changed something in his own software. It is the fact that he has "apparently" ignored the pleas of people to put back something that "wasn't broken" and, in fact, made that change without asking his users first. That is what is a let down. If asked, it is obvious that tons of us would have said... "no, please don't do it". Perhaps he has explained somewhere why he thinks the new way is better and why he thought the old way was so bad that it needed removing?
Sonik_C
Nobody is crucifying the developer, it's his software at the end of the day. But, let's face facts here, most people are NOT happy with this change! As I said in a previous post, just look at the amount of views/posts on this thread compared to others! If that isn't a clear indication that people are unhappy/concerned, then I don't know what is!??
The Dev is just "pushing on" with his vision, without paying any attention to the main problem, which is the complete removal of the old UI.
The solution isn't to tweak the new UI and ditch the old one. The solution is to actually LISTEN to user feedback, keep working on the new UI if so desired, but at the very least, give people the OPTION to keep the old layout!
People are welcome to use this new layout if they so choose, but there was absolutely nothing wrong with how it worked before. The old UI works much better for many people, as has been stated quite a lot here. Why just completely remove it?? Terrible decision! THAT is why people are voicing their concerns! I have no issue with people wanting to use the new layout, I just have issue with the lack of an option to keep the old layout. And I'm sure many others here feel the same!
Yes, this is just my opinion, and will most likely be completely ignored as I only have 10 posts here, but this is absolutely THE WORST change that has happened to this software! The new layout just doesn't work for many people. Just read through this thread, it's really not that difficult to see!
bazbsg
The change was made because the developer DOES listen to user requests. There were at least several users asking, including myself. But in my request I asked to have both the old and the new available and switchable at runtime (without a new Compare step) because there are cases where each is better than the other.
One message from the developer seemed to imply he thought the original list view WAS a tree view. If not aware of what was available out there, maybe that explains why he seems to have rolled his own tree view. I imagine that was a lot more work than just using a control that is already available. But as I stated before, I'm not sure how being able to run on multiple platforms makes the development more complicated. My experience is WIndows programming from back in the XP days and earlier where I could have just popped in an MFC CTreeView. Maybe there isn't a control available today that would run on all the platforms supported by FreeFileSync and rolling his own was the only option??? Unfortunately, what came out is not what people were hoping for and hence there are a many more people asking to go back than that had asked for the tree view in the first place.
I hope that an option to use the original view is given soon and that the tree view continues to be improved.
bgstack15
I have written a patch that adds a "Traditional" view for version 11.1! It is too long to include in-line here, but it's on my gitlab: https://gitlab.com/bgstack15/stackrpms/-/blob/master/freefilesync/debian/patches/ffs_traditional_view.patch
Zenju, please consider including this patch in mainline FreeFileSync. But for anyone who wants to build with this patch, here you go!
2020-09-19 edit: point to most recent version of patch
Musenka
Some people here stated that Tree View "hides" paths for cases when there are many files listed in folders so scrolling down the list hides the path and mouse hovering is needed to check the path. I do not understand these statements. Here are 3 screenshots of the same list in Tree View in 3 random scroll positions. The list is rather long and contains many hundreds of files. When I scroll down the list the full path is always shown on the top line so you always see the exact path in any scroll position. This is very convenient, at least for me.
3 random scroll positions - and full path is always visible on the top line:
As to other topics - I quite agree that OPTION for view type (plain view / tree view) with possible another OPTION for max horizontal space saving mode (for very very long paths - see previous discussions) would be very helpful for all. Personally i always prefer Tree View because it has many strong benefits discussed before (for example, see my posts on this subject) and I find it convenient but I understand that some people hate Tree View and do not want to use it at all.
P.S.: I am still using version 10.25 for Linux for reasons I already mentioned before, but I'm going to test new versions of course and transfer to them sooner or later.
Musenka
I tested the latest 11.1 and found it to be a clear good improvement. Visualization issues noticed in 11.0 are repaired. Moreover, resizing of FLOATING "Configuration" window in Linux version works well now!
My previous post about the fact that full paths are ALWAYS visible in tree view even for very long file lists and scrolling does NOT break things fully holds for the latest version 11.1.
3 random scroll positions (in the same folder) - and full path is always visible on the top line (version 11.1):
Thanks for very good work, Zenju! The new version is really an improvement!
JPringle
Another good thing in 11.1 is that the background color is now grouped by directory (and not every other file) : much better!
But please consider colouring the files on each side according to whether they are saved or deleted/updated
Novgorod
Hi!
The new tree/flat/whatever hybrid view is fine and I don't have much of a preference, BUT why can't I collapse the folders anymore?? That was one of the most important features in the overview and now everything is expanded by default (which is fine) but without the option to collapse folders (which is the opposite of fine). My backups contain software installations or project archives with many thousands of items per piece, so it's virtually impossible to scroll through. Previously, I could just collapse the folder if it just needs to be mirrored or doesn't exist on the target and quickly go through the entire list. Now you have to highlight the folder (which highlights the sub-items) and manually drag the scrollbar until you find the end of the highlighted section (if you're lucky and don't scroll lightyears past it).
So please add back the folder collapse function.
lawrence-dol
I don't have a significant interest in this debate -- I have a 50" 4K monitor, and though I sync a few million files daily, both locally and remotely, FFS meets my needs either way as I can maximize my window and have no truncation or misalignment. I've donated occasionally, but I consider FFS to be essentially free; frankly I don't care for the entitled tone of some of the posts, but, despite that, I assume that they are meant in good faith. For my part, speaking as a fellow programmer, I thank the author and appreciate his work, which, I can assure you all, is not trivial.
With that said, and as I've commented before, the new view is demonstrably a step backwards. The new layout does not save any horizontal space, it does not make the list more readable, and the misalignment that occurs trying to keep the file name displayed is simply confusing.
There are, in my opinion, only three useful ways to display the list, and I would like to see all three, and be able to switch between a flat and tree layout without resynching (which should be no problem as the underlying data must be the full filenames).
Option 1 is the original list, with mouse-over to display the full path of a truncated filename. I think this would be far more useful if the ellipsis was rendered in the middle of the name, e.g. "c:\users\...\some\file" when the filename doesn't fit.
Option 2 is a tree-like layout (directory folding would be very nice, but is not essential to me). This will maximize horizontal space at the cost of additional vertical space, and "empty" folders should be combined on a single line to avoid unnecessary vertical space. This looks like:
Sync Root Folder 1
  File1
  File2
  File3
  A Subfolder
    File4
    File5
    Subfolder\with\some\empty\folders
      File6
      File7
    Another Subfolder
      File8
  And so on
Sync Root Folder 2
  AsAbove
    Etc etc
  You get the idea
Option 3, as I mentioned in a previous post, would regain significant horizontal space by splitting the current two-pane left/right display into three panes, filename/left/right. The filename would then be shown only once, with a left/right pane for the file details to indicate which side is newer and which direction it's going to go. This would apply to both an improved original view and a tree view, whereupon only the first pane would change when the view is toggled.
So I'd like to see a program option for a two-pane or three pane view, with a list toggle for tree layout and flat layout. But if nothing changes, or it's reverted to the original view, then I'm not complaining either.
Sonik_C
I don't think anyone here has acted entitled, just because they've been voicing their concerns about something. As I've said before, it is the Dev's software and he can do what he wants. But, a lot of posts here have been asking the Dev to reconsider and reinstate the old layout as an option, for the last 3 months. The new layout could have at least been beta tested by a small set of users, before being forced on everyone.
Even some users who prefer the new layout still seem to think the old one should be an option. Some people here are unhappy, but I don't think anyone here has acted "entitled" for voicing it.
It's still the best backup software in my opinion. It's just a shame that I've been unable to update past v10.24 for the last few months, as the tree view doesn't work for me. Other users here feel the same.
I'll stick with this version for a while, and if nothing changes then I'll have to eventually find something else that suits my needs. I'd rather not though, because I've been using FFS for years, and I'd really like to continue using it with updates.
bazbsg
"A option toggle would seem to be the way to go so folks could pick their poison."
In Windows, a checkbox has a well established functionality. I would prefer it follow that. However, if a checkbox has a different functionality in other operating systems that this program supports, then I would suggest that the checkbox follows the functionality of the OS it is running on. I would accept an option toggle in that case as a second choice.
lawrence-dol
I'm trying to stay positive, but in the latest release (11.2) the list has become even less readable.
JDB
Below are 2 listings of the identical directory structure using version 11.2 (top image) and 10.24 (bottom image). ... except for 2 files that snuck into view when switching the software. The 11.2 version on the left is "noisy" and mis-aligned. My eyes dance around and I find it difficult to come to the conclusion that all the files in the right folder don't exist in the left folder. The tabular format with randomly placed cell divisions and right-justification is really confusing. It's aggravated by the fact that the cells are too small, and higher level directory names end with "...". True, if one studies it, it can be deciphered; albeit not "at a glance", which is possible with 10.24.
Looking at the version 10.24 example, I can instantly observe which files in the right folder don't exist in the left folder. I don't have to study the chart carefully as I do with the 11.2 example. Also notice how inefficient the 11.2 version is in terms of utilization of vertical space. I don't care if the pathnames are truncated in the 10.24 view, because the mouse-over event is very fast and reveals the full pathname with a consistent effect, simply by scrolling up and down the list. When the ellipsis ("...") appears, it's at the far right and doesn't cut off higher level parts of the pathnames. With 11.2, the mouse-over popup dances all over the place, and seems to have a quarter-second delay added.
I would really like to see the 10.24 output format reinstated. Thank you for your consideration!
Also, please, if you are planning to NEVER change the format back, please announce this with a sticky post so that everyone can stop fussing and learn to live with that decision. Thank you.
Version 11.2:
Version 10.24:
JPringle
I've made several proposals about how to display files that will be updated/deleted or those that do not exist on either side of the sync, here for example. But so far this has not been accepted.
I still think FFS is an excellent product but it's a bit of an interface issue. It deserves a real graphic designer's eye over the technical side of the software (excellent, I repeat).
BatHam
Hello, I think FFS is terrific and I have been donating for years. Unfortunately I am visually impaired and I find the tree view very hard to see. Can I get a version with an option to show the original format?
I have tried a different program called GoodSync and I can see that quite well. I bought FFS licenses for 3 machines and they run until 2023, any chance I can recover my donation (so I can buy the GoodSync instead).
Sonik_C
Sorry to bring this up again, but just installed v11.3 and the layout still seems all over the place.
There are huge gaps between some folder names and the files, and there are random icons just plonked all over the place that don't really add anything other than visual clutter. I still don't see how this is an improvement over the old layout? If you're going to add those random icons all over, maybe it would be better to colour the whole line instead for quicker identification of what is being changed. This has been suggested by another user in a previous post, and seems like a better visual indicator.
Reinstalled v10.24!
JDB
Sonik_C -- Thank you for saving me the time and effort of trying the new version. I am resolved to staying on 10.24 forever.
Radish
I've just rolled-back to 10.24 too.
Sorry to say it Zenju but I think you've made a mistake in doggedly trying to get the new view you introduced from 10.25 onwards into any kind of condition that is actually useable and in any way better than the 'flat-view' (as most refer to it on this thread). The new view is just a dog's-dinner. I've stuck with the various incarnations of it up until now, but I just plain now give up on it. Please give users the choice or scrap the new view altogether. Until either of those things happen I'll stick with 10.24.
phhowe17
I'm staying current. I mostly like the new format, if Zenju could change the spacing so it was just indented fixed amount per directory level, instead of indented based on the length of folder name, I'd be happy.
lawrence-dol
I'm staying current. I mostly like the new format, if Zenju could change the spacing so it was just indented fixed amount per directory level, instead of indented based on the length of folder name, I'd be happy. phhowe17, 26 Nov 2020, 23:04
That would satisfy me too, though I'd preferred a proper tree with zero-change folders collapsed to one line.
Sonik_C
v11.4 Is this normal? The randomly placed icons now seem to have disappeared, and the folder icons seem messed up.
Reinstalling..... oh you know the drill!!
JDB
Being of a trusting nature, I tried 11.4 thinking that perhaps by some miracle it would be better than 10.24. After one screenfull of total confusion about what the changes were between left and right window panes, I am now switching back to 10.24. I gave it the benefit of a doubt, but doubt turned into dissapointment.
Soon I will be migrating my backup strategy to Macrium.
Sonik_C
Soon I will be migrating my backup strategy to Macrium. JDB, 09 Dec 2020, 05:09
It's been 6 months now, and I don't think the dev is really interested in our opinions tbh. Personally, I hate the new view, and it's not getting any better with these updates. When it takes me twice as long to work out where my files are and where they're going to, then it's a step backwards to me. I'm not an aesthetic man, I just want to get things done quicker and easier. I don't care how "nice" things look. But to each their own. Sticking with v10.24 for a while, and won't be trying anymore updates as nothing will change.
I use Macrium for system images and cloning and it's awesome for both. But, I haven't used it for file/folder backups before.
If anyone has any other good free alternatives they can recommend, please let me know. Been using FFS for years, and haven't even tried any other backup software for a long time, so I've no idea what's good and what to avoid.
bgregory02
I used Backup4All (now in version 8) for a couple of years and was very satisfied. The options are overwhelming but very understandable. It ran flawlessly and their user forum and support was pretty good.
About 6 months ago I switched to KLS Backup Professional 2019 and am very satisfied with it also. I switched because I thought the "restore" functions were more user friendly. It also runs flawlessly BUT they do not have a user forum and their support is terrible (almost nonexistent). It costs quite a bit more than Backup4All. Both have a trial available. You'll have to judge for yourself. Hope this helps. By the way, I am a devoted Macrium fan and have used their file and folder backup functions and although they work well, the file/folder selection GUI is not very user friendly. The imaging is awesome and without rival.
