Glitch on Sync/Mirror <Item not existing>
polyglotinc
Hate to rain on anybody's parade, but I just found this forum/post looking for what's going on with 11.11 running on my system and getting several hundred (out of 372K files) showing up as "item not existing" even though I can see them and open them via Finder.
The drive with the supposedly missing files is a drive on a mac down the local ethernet network. Worked fine for over 372,000 files in date/size compare...just mistakenly says 582 are missing when they are not.
KinsleyProk
maybe you would take a look to GoodSync or Gs RichCopy360 , I think you will not face this problem with these tools , search both KinsleyProk, 06 May 2021, 08:45
Those options are painfully slow compared to FFS t0ma5, 06 May 2021, 09:24
No Way , At which mechanism, you judging on both?
What are the differences between FFS and (GoodSync& Gs Richcopy360) that make you very sure FFS is faster ??
I sure FFS saved me many times but after trying the other mentioned tools, the situation is different!!
