Cannot find specified path
cheerfulnut
Hello all,
I'm sure my question has a simple solution but I'm stumped. The issue is this:
I created an ffs_batch file and want to set task scheduler to run it on a
daily basis to backup files to a network drive. The batch file was created
successfully - if I double click on it, it runs just fine, copying new files
to the network location.
However when I create a task, the log file indicates that it has run - but
copying failed because "cannot find the specified path"
I'm pasting a snippet of the log below (the Japanese portion states "cannot
find the specified path")
Start
Error: Directory does not exist:
"L:\Name\Desktop\"
You can ignore the error to consider not existing directories as empty.
Windows Error Code 3: 指定されたパスが見つかりません。
Warning: Initial synchronization:
One of the FreeFileSync database files is not yet existing:
"L:\Name\Desktop\sync.ffs_db"
Setting default synchronization directions: Old files will be overwritten with
newer files.
Info: Processing folder pair:
Left: "C:\Users\Name\Documents\"
Right: "L:\Name\Desktop\"
Info: Copying file "desktop.ini" to
"L:\Name\Desktop"
Error: Error creating directory:
"L:\Name\Desktop"
I don't understand why it's "trying to create directory". I also don't
understand why the heck it works just fine when I double-click the batch file
but not when I set it to run as a task!
Do you have any solutions/thoughts/advice?
Thanks!
The problem semms to be that "L" is a mapped network drive that is visible to
your user only. But the task planner job is running as another user that
doesn't see this mapping. Using direct UNC syntax (\\servername\folder) should
help.
cheerfulnut
That seems to have done the trick!! Thanks so much Zenju :)
