Love FFS. The Donation edition broke on me after today's update.
Clicking any buttons or trying to open FFS preferences leads to a full freeze of the app, and requires xkilling.
System Plasma 5.27.0
Kernel: 5.19.0-32-generic
I installed free flatpak version, and rejected the update, and managed to sync that way but would appreciate being faster ;)
Cheers thanks, all the best
Linux: FreeFileSync using GTK3 on KDE is hanging
I have the same problem, +1. Just freezes.
System: endeavoros
DE: KDE plasma 5.27.1
Kernel: 6.1.12
gtk3 version: 3.24.36-1
System: endeavoros
Kernel: 6.1.12
+1
Operating System: Kubuntu 22.04
KDE Plasma Version: 5.24.7
KDE Frameworks Version: 5.98.0
Qt Version: 5.15.3
Kernel Version: 5.15.0-60-generic (64-bit)
libgtk-3.0 version 3.24.33-1ubuntu2
Qt Version: 5.15.3
This is due to the switch to GTK3 and seems to affect KDE only.
Let's test something. Are the hangs reproducible if you start FreeFileSync via command line as
GDK_SYNCHRONIZE=1 FreeFileSync
Yes, nothing changes
It seems I have a similar problem on debian with KDE, when built from source.
BTW, the Makefile still references gtk2, is this as expected or should it be gtk3 now?
This worked for me as expected. No hangs.This is due to the switch to GTK3 and seems to affect KDE only.
Let's test something. Are the hangs reproducible if you start FreeFileSync via command line as? Zenju, 22 Feb 2023, 08:25GDK_SYNCHRONIZE=1 FreeFileSync
However, also got this:
(FreeFileSync_x86_64:246593): Gtk-CRITICAL **: 17:29:57.211: gtk_box_gadget_distribute: assertion 'size >= 0' failed in GtkScrollbar
Update: When launched from FreeFileSync.desktop containing the following...This worked for me as expected. No hangs.
However, also got this:fefisy, 22 Feb 2023, 22:36(FreeFileSync_x86_64:246593): Gtk-CRITICAL **: 17:29:57.211: gtk_box_gadget_distribute: assertion 'size >= 0' failed in GtkScrollbar
Exec=GDK_SYNCHRONIZE=1 "/opt/FreeFileSync/FreeFileSync" %F
I've reverted FFS back to GTK2 until this issue has been sorted out.
FFS does a peculiar little dance during modal dialog initialization:
I suspect the Show/Hide pair is triggering the hang, which is most likely nothing more than a hidden modal dialog.
Perhaps someone has an idea why FFS hangs on GTK3 and KDE? Or knows a better way to coerce GTK3 to set correct window sizes?
GetSizer()->SetSizeHints(this); //~=Fit() + SetMinSize()
#ifdef __WXGTK3__
Show(); //GTK3 size calculation requires visible window: https://github.com/wxWidgets/wxWidgets/issues/16088
Hide(); //avoid old position flash when Center() moves window (asynchronously?)
#endif
Center(); //needs to be re-applied after a dialog size change!
Just saw the update and tried it, it successfully opened one dialog but then froze after trying to open a second one. I wish I knew how to be more helpful :')
I can cheer ;)
I can cheer ;)
Is this going to be available for download/installation, or should I download and install 12.0?I've reverted FFS back to GTK2 until this issue has been sorted out. Zenju, 24 Feb 2023, 18:09
The official FFS 12.1 has been replaced with the GTK2 build again.
My installation that auto-updated to the problematic version, is not notifying of an update to pull the GTK2 build. Please, thank you.
Manually download and install using NON-donation 12.1 installer. I found that the donation edition has gtk3.My installation that auto-updated to the problematic version, is not notifying of an update to pull the GTK2 build. Please, thank you. drak, 07 Mar 2023, 16:44
Zenju, reverting the change you mention apparently removes the issue (still built with GTK3).
For anyone interested, a patch for this revert is available here: https://salsa.debian.org/bastif/freefilesync/-/blob/debian/latest/debian/patches/revert_buggy_gtk3_change_in_12.1.patch
How did you determine that? The build should be GTK2-based.Manually download and install using NON-donation 12.1 installer. I found that the donation edition has gtk3. fefisy, 07 Mar 2023, 17:47
I haven't tried redownloading the donation version. Let me know if that's best Zenju, thank you for keeping up with this I really appreciate it.
EDIT: Missed the patch somehow, don't know how to apply it though, thanks for the help in advance
Can someone please tell me exactly how to apply this patch? Thank you so much.
Well, this is what I saw:How did you determine that? The build should be GTK2-based. Zenju, 07 Mar 2023, 18:44Manually download and install using NON-donation 12.1 installer. I found that the donation edition has gtk3. fefisy, 07 Mar 2023, 17:47
1. Downloaded 12.1 donation edition installer when I first saw the update notification. After installing this, I saw the GTK3 issue reported in this thread.
2. Upon learning that 12.1 was rolled back to GTK2, I downloaded the donation edition installer again and re-installed. I continued to see the GTK3 issue.
3. I then downloaded and ran the non-donation 12.1 installer. Now I don't see the GTK3 issue.
Dear Zenju, I have been investigating this a bit since I run on KDE, which caused trouble with gtk3 at the time of 12.1.
Actually, I found that calling only Show() but not Hide() as code currently does since 12.1:
- doesn't create the "freeze/hang" on KDE that appeared in 12.1
- fixes the size of the dialogs (see screenshots)
- there is no flickering on screen
However, I can't test this on other desktop environments like Gnome or any other because I run KDE.
Would that be an acceptable solution for that problem? Do you think this could be integrated in your sources?
The old way (ie. the GTK2 way built with GTK3 (=like the patch I put earlier in this thread)) The new way (ie. with the "patch" attached in this post) The patch (it has .txt extension, but it should have .patch)
I've commented out the Hide()s. This seems to fix the "hangs" on KDE, which are nothing more than the windows staying hidden after a "Hide(); Show()" sequence. GTK3 with all its asynchronicity seems to be responsible for this mess.Dear Zenju, I have been investigating this a bit since I run on KDE, which caused trouble with gtk3 at the time of 12.1.
- there is no flickering on screen daviank, 06 Feb 2024, 22:05
GDK_SYNCHRONIZE=1 seems to mitigate this issue by about 80%, but it's still reproducible!
Drawback: Without the "Hide()" the old position flashes shortly before "Center" on Gnome, which looks really ugly. GTK3, unfortunately is still not ready for prime time.
BTW, I noticed that in the About dialog, only the last Show() must be kept. Having both leads to corruption in the dialog (at the location of the donation text + image)
