when trying to fetch a directory with a file with an invalid charset from an ftp server the whole directory is skiped. Is it possible to skip just the one file?
thbenner
After changing the file name, I got another error message on another file:
Die Datei "ftp://thomas@192.168.188.76/home/thomas/Downloads/FA Einzugsermächtigung 2023.pdf" kann nicht gelesen werden.<br>
Die Zeichenkodierung konnte nicht automatisch erkannt werden: /home/thomas/Downloads/FA Einzugsermächtigung 2023.pdf
Translation: The character encoding could not be detected automatically
The server doesn't advertize itself as being UTF8-compatible, apparently.
When you run the "FEAT" command on the FTP server, what does it return?
thbenner
I have changed the server settings, but there is still a problem:
<td>Das Verzeichnis "ftp://thomas@192.168.188.76/home/thomas/Downloads" kann nicht gelesen werden.<br>
Unexpected FTP response. (-rw-r--r-- 1 1000 1000 185608 Jan 28 13:27 FA Einzugserm�chtigung 2023.pdf) Ungültige Zeichenkodierung: [UTF-8] FA Einzugserm�chtigung 2023.pdf</td>
C:\Users\benne>ftp 192.168.188.76
Verbindung mit 192.168.188.76 wurde hergestellt.
220 (vsFTPd 3.0.3)
200 Always in UTF8 mode.
Benutzer (192.168.188.76:(none)): thomas
331 Please specify the password.
Kennwort:
230 Login successful.
ftp> FEAT
Ungültiger Befehl
ftp> FEAT
Ungültiger Befehl
ftp>
I have enabled the UTF-8 support in the config file but get still this error:
The � character is an ANSI-encoded "ä" stored on the server, decoded as UTF8 by the client (FFS). In other words it's corrupted data from FreeFileSync's perspective. The simplest fix would be to delete the file and upload again. This time it will be correctly UTF8-encoded.
thbenner
Is it possible to switch it to ANSI instead? Whenever a file is saved on the debian homeserver, the filename seems to be Ansi encoded.
thbenner, 26 Feb 2023, 10:15
thbenner, 26 Feb 2023, 15:05
This seems to be a bug of the FTP app that saved this file. Apparently the connection was UTF8, but the app sent the file name as ANSI instead.
