Environment Variables not being expanded properly
dozuki
I've recently been struggling with a change in behavior when using environment variables. As an example, I have a variable set in the system environment in Windows10:
WOW_BASE="G:\Program Files (x86)\World of Warcraft"
This used to expand properly, however, recently it's expanding to:
C:\Program Files\FreeFileSync\"G:\Program Files (x86)\World of Warcraft"
I can't figure out how to correct this. I've tried numerous variations, but it's no longer working. Any suggestions?
FreeFileSync used to strip off double-quotes, but doesn't do so anymore in recent releases. This matches the behavior of the operating systems which also don't use quotes in environment variables that represent folder paths.
dozuki
Thanks, that appeared to do it.
