RealTimeSync enviroment variables on Linux
RCRalph
I've tried to see what files cause RealTimeSync to run.
When I looked into the documentation, I saw that on Linux I should enter the following command:
echo %change_action% "%change_path%" >> ~/Desktop/log.txt
However I found out that this doesn't work. What worked for me was the following line:
echo "$change_action $change_path" >> ~/Desktop/log.txt
If I may, I suggest changing the documentation to include the correct command.
Fixed.
RCRalph
Thank you, there might also be a typo in the paragraph below, it says %changed_file% instead of %change_file%
That should be "change_path", thanks!
