Hi there,
I would like a sort of FTP upload to manage the sync betwen my local folder and Google Drive.
I don't want install Google Desktop software, I mean, I don't want to perform these sync between the local folder and the virtual local drive created after installing Google Desktop.
There is a way to that with FreeFileSync ?
Many thanks for your help !!
Matteo.
Direct upload/sync To Google Drive Cloud.
There is an easy way.
On the left side, select the source local folder you want to sync to Google.
On the right side, select the little cloud icon. This will bring up the window where you can authenticate to your Google account.
I can't figure out how to upload 2 instructional photos.
