How files are overwritten?
Anonymous
First - great software! A copy tool that uses VSS - great!
One question: how does overwriting work - file is overwritten at the start of
the copy or at the end?
It matters when backupping pst-files over network, for example.
Keep up the good work!
The file is deleted first (respecting deletion policy "recycle bin/user-
def-directory/permanently) and then copied.
Regards, Zenju
