Hi to all.
I use freefilesync mainly to make a mirror of my HD to an external one.
I tend to move files (in my computer) from one directory to other just to
order a litle my stuff.
I find that by doing this makes freefilesync to delete the file in the
external HD and then copy it again.
Is there a way to make freefilesync recognize this type of file movement (i
don't know if there's an option there) and just move the file to the new
directory instead of copying it all over again?
That would reduce the reading / wrinting process a lot and therefore reduce
time and increase the life of my external HD.
Thanks in advance for any help!
Moving Files when Mirroring
This feature has already been requested here:
[404, Invalid URL: https://sourceforge.net/tracker/?func=detail&aid=2880632&group_id=234430&atid=1093083]
Ok!
Thanks for your reply.
I'll be looking forward its implementation if you consider it to be possible
and convenient.
Thanks!
and convenient.
Thanks!
