I have a pc with a slow CPU and i start freefilesync with a bat in this way:
Start /Wait /AboveNormal "" "C:\Program Files\FreeFileSync\FreefileSync.exe" "C:\ProgramData\backupControl_pcs\GlobalSettings.xml" "C:\pcs\pcs_scripts\konfig_ffs\ffs.ffs_batch"
In the Windows Taskmanager there a two processes:
freefilesync.exe and
freefilesync_x64.exe
The freefilesync.exe starts as expected with the higher priority,
but the freefilesyc_x64.exe is in normal state, not AboveNormal.
FreeFileSync Start Priority (Windows) ...
Just call the 64-bit executable itself
The FreeFileSync launcher not only selects between 32/64 bit, but also does a number of checks that help troubleshooting weird system issues, so it should not be skipped. The files inside subfolder "Bin" like FreeFileSync_x64.exe are implementation details.
Fixed for FreeFileSync 12.3!The freefilesync.exe starts as expected with the higher priority,
but the freefilesyc_x64.exe is in normal state, not AboveNormal. volker01, 20 Apr 2023, 20:00
Interesting! Might be worth preventing them from being ran directly at all, what are the disadvantages?The FreeFileSync launcher not only selects between 32/64 bit, but also does a number of checks that help troubleshooting weird system issues, so it should not be skipped. The files inside subfolder "Bin" like FreeFileSync_x64.exe are implementation details. Zenju, 21 Apr 2023, 08:41
I can't think of disadvantages other than this one: If I rename the executable to "FreeFileSync_x64.bin" then "pin to taskbar" doesn't work because the file name of a process does not end with ".exe".Interesting! Might be worth preventing them from being ran directly at all, what are the disadvantages? xCSxXenon, 21 Apr 2023, 14:27
That seems okay if they aren't supposed to be ran directly, no?
Unfortunately "pin to taskbar" is also missing if "FreeFileSync_x64.bin" is started through the launcher FreeFileSync.exe. It seems there isn't a way to manually set a different target path for the process.
