RealTimeSync.Exe
Is there some kind of help doc on this?
Well, no ;) But usage is quite simple as explained in the description on RealtimeSync's main dialog.Is there some kind of help doc on this?srjones67
-Zenju
OK. I see how to do this with command line. How does silent mode get set? And it is confusing, why do I have to set the compare directories in the batch file that I will run at the command line and the RealTimeSync Interface?Is there some kind of help doc on this?srjones67
Oh. And the delay. Is it in Minutes?Is there some kind of help doc on this?srjones67
Found Silent. Just wondering on the delay and why do I have to set the compare directories in the batch file that I will run at the command line and the RealTimeSync Interface?Is there some kind of help doc on this?srjones67
> Oh. And the delay. Is it in Minutes?Oh. And the delay. Is it in Minutes?srjones67
No, it's in seconds. I'll enhance the description for the next version.
-Zenju
> why do I have to set the compare directories in the batch file that I will run at the command line and the RealTimeSync InterfaceFound Silent. Just wondering on the delay and why do I have to set the compare directories in the batch file that I will run at the command line and the RealTimeSync Interface?srjones67
If you simply load a *.ffs_batch file the directories are set automatically.
However I decided to allow changing the directories independently in order to completely decouple this tool from the synchronization process:
Thous the user is able to specify some directories to watch and a commandline to execute, which could for example be a notification being displayed if files within these directories change or whatever. This offers a much broader range of applications than restricted to a pure sync-utility.
-Zenju
Is it possible to set the delay time from the command line?
No, all configuration data is passed by a *.ffs_real file (or implicitly via
*.ffs_batch)
*.ffs_batch)
