Sync 64 bit and 32 bit machines
alokg
I synchronize a 32 bit machine with a 64 bit machine. I have FreeFileSync
installed on both machines. It however creates databases with different
filenames when run on the two machines -- _sync.x64.ffs_db_ and _sync.ffs_db_.
This is problematic because if I sync from 32 bit machine, the x64.ffs_db
file is outdated, and vice versa.
Why not same the database in the same format from both 32 bit and 64 bit
versions of FreeFileSync?
This behavior is fine and as designed. It is due to issues discussed here:
[404, Invalid URL: https://sourceforge.net/tracker/?func=detail&aid=2963611&group_id=234430&atid=1093083]
