check file permissions of source files if they won't sync
jimwspoon
I kept on getting ERROR_ACCESS_DENIED messages on certain files that wouldn't sync. I dug around for awhile and finally remembered that this had before. The problem was that I was logged in under a non-admin account that did not have permissions for those files. I could sync the files by running FFS as Admin, but then the problem might reoccur for those files if I didn't run as Admin. So I decided to change the ownership and permissions on those files. I ran FFS under the non-admin account, and again these files failed to sync. Use any method or tool you have to get to copy the pathnames of all those files. (I Ctrl+C copied them to an xplorer2 "scrap window", and then used Alt+C to copy the pathnames of all the problem files.) Then I followed the method here to change the ownership and permission of the files - https://answers.microsoft.com/en-us/windows/forum/all/how-to-change-permissions-for-multiple-files-at/be2d12bf-cb88-40c0-a6f2-5be43966e114 . After I did this, these files synced with no problems, even running FFS under a non-admin account.
therube
(On my end, you cannot click the above link & have it actually load the expected page?
Maybe if you were "logged in" to MS or some such [crap]?
Copy & paste of the link does allow it to work.
https://login.microsoftonline.com/common/oauth2/v2.0/authorize?client_id=a81d90ac-aa75-4cf8-b14c-58bf348528fe&redirect_uri=http:...
What absolute nonsense MS is.)
jimwspoon
Hi therube, not sure why that link didn't work, but the title of the thread at answers.microsoft.com is "How to change permissions for multiple files at once?" - maybe you can pull it up with a search. Anyway the procedure is pretty simple. The instructions were to run this command on every file to change ownership:
takeown /f "full path of file"
And to change permissions -
icacls "full path of file" /grant (USER NAME):F
I copied and pasted the whole list of paths that didn't sync in FFS into Excel. Then I used formulas to make the above command lines for each file, in a column. I pasted that column into a text editor and saved it as a batch file, then ran the batch. The ownership and permissions for each file was changed successfully. After that I ran the same sync in FFS as before, and now the files synced.
So you changed permissions of files and posted that here why?
jimwspoon
So I can get a start on catching up with your 2837 forum posts. You have my deepest admiration.
