Results screen suggestion: sort by file size
WhataMack
Hi, I've been using FreeFileSync for awhile and have a suggestion about the log results screen. I think it will be helpful if the results can be sorted by size of the files that have been synchronized. I've been interested in seeing that as part of the results but am unable to do so. If you'll consider adding this to your excellent software it'll be much appreciated.
