Hi, I would like to report a problem with Freefilesync. If I try to compare an entire partition from an Ubuntu laptop to an Ubuntu desktop (with some filters), the software hangs with "Searching..." (or something like that...I use it in italian).
If I try to compare a sub-folder into that same partition, I don't have the problem.
Can you fix this?
FFS hangs when comparing entire partition on Ubuntu
