I wnat to use my USB-Stick to have the same data-base on my two Computers.
Can I manage this with FreeFileSync?
Is it better to install FreeFileSync on the USB-Stick.
Regards, retorix
USB-Stick sync with two different Computers
Sure, this is the "standard" synchronization scenario.
It doesn't matter where you install the tool. You can even install a 32 bit
version on one pc and a 64 bit on the other and synchronize them via the usb
stick.
stick.
