uninstall or re-install, ver 5.7 Missing from win 7 uninstall programs
Free file sync (ver 5.7) does not appear in the list of programs that can be uninstalled (win 7). I need to move this program to a new location and would like to uninstall it and re-install it in another folder. There are references to ffs in the registry, which would need to be dealt with.
You should see an entry in the installed programs list, unless you used "portable" installation in which case you can just move/copy the installation directory whereever you need it.
BTW: What registry entries are you seeing?
That seems reasonable.
Based on your reply and the looks of the actual registry entries (copy attached), they appear to be things other software has stored concerning ffs.
Many thanks for your very helpful reply.
Thanks for the follow up on the registry entries. I can confirm none of those entries is created by FFS.
