Access denied error - wrong folder
ladarrius
This is a bit of a weird one to describe since it depends on access permissions to test...
The Setup
Win10 FFS 12.5
The location being synced is from a NAS (N:) to a local drive (L:)
Folder pair
Left - N:\
Right - L:\
Filter
Include: "\lorem\ipsum\dolor\" - note, NO include "*" (wildcard)
Exclude: the usual
NAS permissions
N:\lorem\ipsum\ - not allowed to access
N:\lorem\ipsum\dolor\ - allowed to access
in windows explorer, trying to access \ipsum\ will give an error, trying to access \dolor\ will be fine.
The error
When running FFS I get this error
Error:  Cannot open directory "N:\lorem\ipsum".
ERROR_ACCESS_DENIED: Access is denied. [DirReaderPlus]
even though \ipsum\ is not a directory that is supposed to be synced,
and \dolor\ does not get synced at all even though it should be accessible
Expected behaviour
FFS should not be trying to check \ipsum\, or ignore the error, and should be syncing \dolor\
Thanks!
Directories are expected to be traversable beginning with the base folders. In your case you would have to set "\lorem\ipsum\dolor\" as a base folder.
That is
Left N:\lorem\ipsum\dolor\
Right L:\[the dolor folder counterpart]
And, of course, change your Include Filter back to the * wildcard,
because \lorem\ipsum\dolor\ is not a (sub)subfolder within
N:\lorem\ipsum\dolor\ or its L:-side counterpart.
ladarrius
thank you both for the quick answer and solution
just curious, what is the rationale for this?
would there be a downside to just jumping straight to the path that is specified?
