When syncing I occasionally get a message "Same Date but Different Size". I usually select the files and force an overwrite of the backed-up version.
Can't we have a feature that allows the setting of an "action" to be carried out against certain errors?
I plan to execute a lot of automatic backups and this specific error handling would prevent stops fro what would be acceptable errors.
Error handling options for sync.
