Hello, may I inquire whether it's possible to modify the "sync.ffs_db" file under Windows to make it both a system file and a hidden file (this can be achieved using the command line "attrib sync.ffs_db +s +h")? Alternatively, is there an option in the settings to achieve a similar outcome?
I currently have Windows File Explorer set to show hidden files but not display hidden system files, so I would appreciate it if FFS could automatically set the "sync.ffs_db" file with system and hidden attributes.
About files "sync.ffs_db"
You can set that manually. It wouldn't be appropriate for FFS to set it as a system file, because it isn't one
