One-off sync
sdicandia
Hi, I need to transfer files regularly from a remote machine to a local external hard disk: once transferred, they are moved and stored away, but they remains on the source machine.
Is there a way to "flag" the files already transferred so that they are copied (left to right) just once ?
Thanks in advance,
Sergio
"Moving" is not directly supported by FFS. It can be emulated by two sync jobs, e.g. the first one syncs/copies using the "update" variant, the second one deletes the source files by using an empty input field as source. But I agree this is probably very clumsy.
sdicandia
Thanks, but I need to keep the files on the source machine, and just avoid to retransfer the ones I moved from the target.
Sort of Iincremental copy, with no subsequent check of existance for files already transferred.
Okay, so you only want to sync the files which are new since last sync. You could try the "filter by timespan" and depending on how often you sync select for example a time span of one day if you sync the changed files at the end of the day.
