See pic here: https://drive.google.com/file/d/1fgxv7TYpTWCXhuDOJwS0RZIvZcFxbz0T/view?usp=sharing
How to fix this? I read some of the other threads on this but the answers were too technical for me to figure out. Is there a simple solution?
How to fix "Cannot Set Directory Locks" error? See pic.
You'll have to figure out why that volume is set to read-only and disable it
https://docs.kernel.org/filesystems/erofs.html
https://askubuntu.com/questions/197459/how-to-fix-sudo-unable-to-open-read-only-file-system
From my time using Parted Magic, I typically use '/media/sda1/' or something similar, I don't see any volume designations in your paths. I don't know if that matters or not. This is one of those "just Linux things" that keep people on Windows
