As part of my portable browser installation there is a file called FirstRun that has no extension. If I include the parent folder it gets copied across with everything else. But I only need that 1 small file, but FFS can't see it if I try to add it as a file.
Is this possible to do and I am just too dim to see it?
How to backup files with no extension
So you only want the file, FirstRun, & nothing else (in the particular directory)?
Any other "firstrun's" in that directory?
Set an Include Filter of (only); firstrun*
Otherwise, explain further?
In the folder there is a subfolder and that 1 file FirstRun that I want.
The way I have done it this time is to include the main folder, then click on every single file in the subfolder except for the one I want and the Firstrun file so that they get copied alone.
I've never even looked at filters yet they look a bit complicated tbh
