Hi! My Google Drive upload speed ranges from 300 bytes - 2.5KB per second.
I uploaded a 30MB file manually to Google Drive in about 2-3 seconds.
What can I do to speed up FreeFileSync Google Drive upload speed?
How to speed up Google Drive uploads
It should be transferring at the same speed. Are you using FFS to transfer to GDrive directly or to a local copy that then syncs to GDrive via the program
I'm uploading directly via the GDrive Connection feature within FFS.
What happens speed-wise when you use the Google Drive For Desktop software to copy/sync/backup the files.
Rather than having FFS create its own connection to the server, use the pre-existing connection that you have using the Google Drive software for Windows.
Good idea. I'll try that in the future. FFS finished synchronizing after 3 days lol.
