Run on cronjob
MarcoCruz
I have install FreeFileSync_13.2 on RHEL 8.9.
Can you help on set it to run on crontab/cronjob every 10 minuts.
I have tried like this, but it do not work:
*/10 * * * * user /opt/FreeFileSync/FreeFileSync /home/pacs/SyncSettings.ffs_batch
All the paths are ok.
If I run it on cmd like this "/opt/FreeFileSync/FreeFileSync /home/pacs/SyncSettings.ffs_batch" it works.
Can you help.
Thanks.
Have you tried to follow the manual?
MarcoCruz
Yes I have fallow the manual but for RHEL 8 it do not have gnome-scheduled.
MarcoCruz
The command : "/opt/FreeFileSync /path-to-config_file/config_file.ffs_batch" doesn't works on crontab, while it works when launched from terminal window.
It is very strange
bgstack15
You are probably missing the DISPLAY environment variable. See my old post.
