Waiting For missing directories - overcome this for a drive that is removed from the network?
stockers1983
I have a server that is serving 3 laptops. The laptops need to have a common folder synced.
This folder is called 'company' for example and is stored on the server.
On each of the laptops, there is also a folder called 'company'
When all 3 laptops are in the office snd connected to the network, RealTimeSync works as it should so I know all permissions are correct etc.
However, if I remove 1 of the laptops from the network, it says 'Waiting for missing directories' and the sync does NOT run.
I would like the sync to still take place on the remaining laptops and for the 3rd laptop to be able to join back in when it returns to the network.
Is this possible using RTS?
Regards
Yes, but you will need to spawn three instances of RTS, one for each folder pair.
