How to disable logging?
mindstormer12
I'm trying to seamlessly automatically backup my flash drive. I want to insert my flash drive and have it automatically backup to a folder on my computer without having me to open FreeFileSync. I want to edit files on my flash drive and have it sync in real time to my folder without me having to open or see FreeFileSync at work.
So far, I created a batch file and have it run on RealTimeSync. Problem is, every time I save something on the flash drive (for example, I ctrl + s ~ every 2 minutes when I'm working on a document on my flash drive), I see a message popping up saying logging is completed and I actually have to close the message and begin working on my document. Such a hassle and distracts me and I really don't need the logging.
How can I disable it? Thanks.
Not sure which message you are talking about, but both FFS's results dialog and logging can be deactivated in config settings.
mindstormer12
I'm talking about this message box "Completed. Logging". For that example, I just created a new document on the flash drive and saved it, then that message displays. I'm looking for a way to stop this message from displaying it--I clicked the green cog and chose Ignore under Error Handling, then selected "On completion: Close progress dialog." I still get the message box.
*Oops, looks like I can't attach an image of the message box.
Either "close progress dialog" in "on completion" or unchekcing "show progress dialog" will do.
mindstormer12
I already selected "close progress dialog" in "on completion" but still get the message. I don't see anything on unchecking "show progress dialog"
srjones67
In FFS on Program menu, "save as batch job" then in the next dialog click on the "Batch settings" tab.
mindstormer12
Ohh... don't know how I missed that. Thanks so much. This thread can be closed now (if that's how it works).
