Would it be possible to use FreeFileSync to synchronize with Microsoft (OneDrive) accounts the same as used with Google accounts (Google Drive)?
Greetings...
FreeFileSync with OneDrive
Thank you, but unfortunately in none of those threads answers my question.
Greetings...
Greetings...
That's false
You can sync to the OneDrive folder that is locally stored on the computer. Then that will upload it to the OneDrive cloud. You can't, currently, sync directly to the cloud. xCSxXenon, 25 Oct 2020, 16:36
It is true since I do not use OneDrive or intend to use it.
Greetings...
Greetings...
Then your initial post is inaccurate as that is exactly what you were asking about.Would it be possible to use FreeFileSync to synchronize with Microsoft (OneDrive) accounts the same as used with Google accounts (Google Drive)?
Greetings... Songoku, 09 Feb 2024, 18:09
That is not what I asked. I asked if I can use freefilesync with Microsoft accounts in the same way that is done with Google accounts. In my previous message and clarified that I do not even use the program called OneDrive, nor do I intend to use it. But my original question is still standing, and even unfortunately I have not seen any response to it, neither in this thread nor in the linked threads.
Thanks and regards...
OneDrive is Microsoft's cloud storage service. Whatever, you've made it clear that you couldn't pour water out of a bucket with the instructions written on the bottom.
When I say "OneDrive Program" of course I am referring to the application that installed in the operating system allows synchronizing local folders with the Microsoft account. My question was very clear in all my messages and it is perfectly understood. If you don't want to answer her, or don't know how to do it is your issue. It should not provide confusion to the thread just to avoid responding to it.
Greetings...
Greetings...
