synchronize directorie with subdirectories
Jahk
Good morning,
I have been using your software recently and a problem arises:
when I want to synchronize (mirror) my source target containing 3 subdirectories it tells me that many files must be updated but when I synchronize my 3 subdirectories independently the software tells me that the 3 targets are identical to the 3 sources !
I don't understand !? Could you please explain and help me.
Thanks in advance
Jahk
You probably defined your left-right base location(s) incorrectly for your "all 3" sync.
If Source and Target are the (intended) parent of Sub1, Sub2 and Sub3
you should have a single left-right pair
[Source] => [Target]
OR
you should have three left-right pairs (using the "+"-icon in front of pairs)
1) [Source]\Sub1 => [Target]\Sub1
2) [Source]\Sub2 => [Target]\Sub2
1) [Source]\Sub3 => [Target]\Sub3
Jahk
hello Plerry,
thanks for your answer.
a) [Source] => [Target] (with subdirectories) no results
but
b) 1) [Source]\Sub1 => [Target]\Sub1
with this, of course the subdirectories are ok
so thanks for your time
Jahk
