FR: Run command BEFORE sync
FreeFileSync allows the user to run commands AFTER sync. It would be great if you could please add the option to run commands BEFORE sync. Thanks!
BEFORE.bat:
DEL C:\COPYSTUFF\*.TMP
COPY C:\COPYSTUFF\* C:\IREALLYOUGHTTOBACKTHISUP\
ECHO Ready to back up...
pause
{PATHTOFFS}\FREEFILESYNC.exe -DirPair C:\IREALLYOUGHTTOBACKTHISUP\ X:\MYBACKUPS
Thank you for the suggestion. Unfortunately, something like that won't work well. I have many FFS configurations in the 'Configurations' panel, and I use the FFS GUI to run each configuration as needed. Depending on the configuration, I want to run a tool before the sync process starts. FFS provides a field within each configuration's settings to allow a tool to be run AFTER that sync is done, and I am requesting a similar field in each configuration's settings to allow one or more tools to run AFTER that sync is done.BEFORE.bat:therube, 04 Mar 2024, 16:27DEL C:\COPYSTUFF\*.TMP
pause
Still not what you're wanting then, i.e., directly from within the GUI, but if you still start from a batch file, & you can do the BEFORE before, & then you can pass the wanted .ffs_gui / .ffs_batch name to FFS (so that at least gets your BEFORE & sync order are in the order you want, in a somewhat more automated way).
I too would like to see an option added to "Run command BEFORE sync" so that I can automatically wake up the remote host that I'm trying to sync with. In Windows, "\\hostname\\C$" doesn't wake up the remote host, thus I have to manually do so every time I want to sync. Would be much, much better to be able to automatically wake the remote host. Thanks, Bob
