freefilesync 13.4 SymLink in windows 11 problem
icyhoty2k
Problem with symlink on windows 11:
Hapeens with mklink /d , mklink /h , mklink /j
Reproduce:
1.mklink /d testlink21 d:\01_BACKUPS\
2.Start freefilesync as admin Sync from windows 11 pc ntfs fs to a nas on ext4 fs
3.view images for details
https://ibb.co/XD9tncT
https://ibb.co/stC2kQZ
What is your Symbolic Link handling setting (in the FFS GUI Comparison (F6) tab)?
What file system is your \\q\ location? Not all file systems support reparse points.
icyhoty2k
\\192.168.0.20 (\\q\) is a ext4 file system , but this happen also on windows to windows ntsf to ntfs too.
Include sybolic link : AS LINK (NOT FOLLOW)
icyhoty2k
try it on windows to windows its the same!
therube
Looks to work - Win7.
C:\TMP\BRU\dir_holding_a_symlink>mklink /d spacedout-symLINK C:\TMP\BRU\spacedout
symbolic link created for spacedout-symLINK <<===>> C:\TMP\BRU\spacedout
C:\TMP\BRU\dir_holding_a_symlink>dir
 Directory of C:\TMP\BRU\dir_holding_a_symlink
03/20/2024  11:22 AM    <DIR>          dir1
03/20/2024  11:22 AM    <DIR>          dir2
03/20/2024  11:16 AM    <SYMLINKD>     spacedout-symLINK [C:\TMP\BRU\spacedout]
1. non-Admin, so it will fail*
(*actually, it depends, as in some circumstances it looks to work)
2. non-Admin, failed
3. Admin, before sync
4. Admin, sync worked, re-Compared & "equals" displayed
icyhoty2k
look at the erroe you get vs the error i get ..probably symlink cannot be copyed from windows to nix:
In *nix a symlink is typically just a plain text file with a "symlink" attribute. The file contains the path to the link target. The "symlink" attribute does not exist on Windows.
https://stackoverflow.com/questions/23380231/how-to-copy-symbolic-link-file-from-linux-to-windows-and-then-back-to-linux-but
