Hello!
This may be a simple question, but I still don't know what would be 100% correct.
There is FTP on the right. There are several folders on it that need to be synchronized with the same folders on the local computer on the left - add new files from this FTP to the left and update existing ones. There is no need to delete anything on the left under any circumstances.
What would be the most correct and reliable synchronization scenario here? Is it possible to see exactly screenshots of this script in the program?
Thank you.
What is the best way to synchronize?
FTP on the left, local on the right, 'update' sync method
Thank you.
But the "Update" method can also be different.
Can you provide a screenshot?
For example, I don’t quite understand the difference between the icons for the right side: “Do nothing” and “Update element on the right”.
How can I set them all correctly in accordance with my requirements?
Then use the Custom sync variant.
In that variant you can customize which actions are taken for the different Compare result categories.
