I am using FFS and paid for a business license. I see this message (in red) each time it runs via task manager, is this an issue or just a notice stating the obvious "the following batch options have been changed.."
Thanks for any help!
Sounds correct. I assume you meant "Task Scheduler", not "Task Manager". If so, your configuration might be set to stop syncing if there are errors, so then the user can read it and choose what to do next. Since user interaction isn't allowed/possible, it must be detecting that this would cause a conflict and changes it on-the-fly to 'ignore errors'. That's what it sounds like
szymas
Correct, task scheduler. So, then you are saying I can just ignore that message unless I change a setting in the batch file that says not to stop syncing if errors happen.
