I know that this must be easy to do but I cannot find it: When I start my backup by double-clicking on the backup job (.ffs_gui file), it comes up and scans for changes and when it is done, I can hit "synchronize" and it starts copying.
Any way to make it just start copying without user input when it gets done scanning for changes?
Thanks.
Remove need for confirmation
Save it as a .ffs_batch file instead. Open FFS, select your configuration, click 'save as batch job' in the top-left, choose the settings you want, and save. Double-clicking a batch configuration will run automatically.
Thanks, that fixed me up perfectly!
