Recycle-bin on external doesn't work
marsch
Hello everyone,
I have an external drive which has a recycle-bin and it's working when I delete something via the Explorer...
When I use FFS I get the notification from FFS that FFS can't use the recycle-bin.
Does anybody know why?
For internal drives FFS can use the recycle-bin.
Cheers
Markus
marsch
I'm very sorry, I got it wrong, it's the drive of another PC in the network which has no bin for other PCs in the network, all is deleted directly and gone forever...
Can I change that? Can I activate abin for a network drive of another pc?
No, network drives don't support Recycle Bin. You can change it to permanent deletions or set up versioning to maintain your own 'recycle bin'
You can use Versioning
marsch
Wow, thanks. That's it! :)
