I run fairly large sync jobs, typically between my local NAS and GDrive.
Several of my jobs fail, actually causing my Mac (a Mac Mini 2) to reboot. I had thought maybe something was wrong on the Mac but I got a new Macbook Pro and I have the exact same issue. I also had this on my previous Mac Mini 1. The logs are of course not there because the job does not complete.
I have one job on which this is 100% repeatable.
My workaround is to run a Windows 11 VMWare instance on the same Mac, with the same files and the sync job completes fine on there. I really don't want to have to run a VM just for FFS though.
I'd be happy to work with a dev using a debug version to help try and narrow and solve the issue. I suspect the Mac version is running out of memory or there is a similar issue. Clearly actual RAM is not the issue if I can complete the job on a VM on the same machine.
FFS crashes my Macs
Anything on the Mac end which may have logged data about the crash (reboot)?
Maybe post its' settings.
Anything special, peculiar with particular files in that job?
Anything special, peculiar with that job?100% repeatable
This is a straightforward Mirror sync, most settings are default. My Mac just says the system was restarted due to an issue, in the middle of the Sync job.
As I said, the same sync works fine in Windows. I think there's memory loss (or similar) with a large number of files on Mac and it has been this way for at least a couple of years - I posted about this previously but got no response to address it.
So I have to use Window (or a Windows VM) for anything that involves 1000+ files.
