openSUSE: Failed to start (donation edition)
bladewinds
just installed the donation edition by running the .run file and it installed successfully.
However, when I tried to start the program, I got the error:
Failed to start "/opt/FreeFileSync/Bin/FreeFileSync_x86_64".
Any ideas how to fix this?
I tried to uninstall and install it again.
Thanks.
The window doesn't show error details, which I've fixed for the next release.
In the meantime, when you run "/opt/FreeFileSync/FreeFileSync" from a terminal, what do you see?
bladewinds
In the meantime, when you run "/opt/FreeFileSync/FreeFileSync" from a terminal, what do you see? Zenju, 11 Jun 2024, 08:49
I get this error.
Edit: fixed by running:
sudo zypper install libgthread-2_0-0
Maybe the installation script should check for dependencies and install the missing ones.
