Linux: Freefilesync does not write on exfat drive
uri2510
when I try to sync from my Linux drive to an USB Stick formatted with exfat I get the following error message:
"The file "/media/ulf/PC-daily-BK/documents/BDA_CometDECT__07_2020-c35d.ffs_tmp" cannot be written.
EACCES: No authorization [open]"
I can answer whatever I wand, the synchronisation fails. No data is synced.
I have full access to the stick. The stick is mounted with my priviliges. Sync option is update the right side. The versioning directory is set to the program folder.
What can I do do to get rid of that problem.
Thanks for your help
