Spelling errors in code tree - Unknow
kathenas
Spelling errors in code tree - Unknow.
While reviewing your application for Debian.
Lines 149 and 173 'Unknow' needs to be changed to 'Unknown'.
Regards
Phil
kathenas
Spelling issue.
In file: 'zen/sys_info.cpp', change 'Unknow' to 'Unknown'.
                 "INVALID",
                 "Unknow",
                 "empty",
                 "O.E.M.",
                 "O.E.M",
                 "OEM",
                 "NA",
            if (equalAsciiNoCase(cm.model, dummyModel))
                cm.model.clear();
                break;
        for (const char* dummyVendor :
                 "OEM Manufacturer",
                 "SYSTEM_MANUFACTURER",
                 "System manufacturer",
                 "System Manufacter",
                 "To Be Filled By O.E.M.",
                 "Default string",
                 "$(DEFAULT_STRING)",
                 "Undefined",
                 "Unknow",
                 "empty",
The entries are "correct" in the sense that they are used by some device manufacturers.
