Sort columns
Phill
Is there any way do do an alphabetical sort of the columns being synchronized and the destination folders together. Thanks
Right-click the column header and choose "item name"
Phill
Not sure what you mean by column header. At top of column is name Compare, below that is Drag & Drop, at the bottum of the Compare column is Relative Path. If I right click on Relative Path and choose Item Name all is does is change Relative Path to Item Name. How does this sort my complete list of folders to be synchronised into alphabetical order. My reason for wanting to do this is if I want to synchronise a new folder I have to go searching down the list to make sure is is not already set to synchronize. If the list is in alphabetical order it would be much easier Thanks Phill
