Hello—as long as we're here:
1. What issues will I see from FFS while syncing EFS folders to backup disk
2. Not sure why the occasional saved email is showing access denied - I am running as admin.
TIA
Sync EFS folder(s) & access denied to saved email files
1. Hopefully none, report back if you do or don't!
2. We're not sure either, not enough info
Rather than risk it I unencrypted the source and encrypted after transfer. Being new I am still learning and may write a piece after more experiences.
I am looking into which emails transferred -v- the ones that failed. I thought someone had a knowledge and would pop in with a 'try this' message. It was an after thought and I shouldn't have added it.
Thanx,
EdwardR
Thanx,
EdwardR
