I have 4 files in .tar.gz format in google drive. When I use FFS to sync, the larger two (500MB, 1.5GB) get copied successfully but the smaller two (10MB, 20MB) give the following error:
[X] Cannot read file "xxx.tar.gz"
CURLE_OPERATION_TIMEDOUT: Operation too slow. Less than 1 bytes/sec transferred the last 10 seconds [curl_easy_perform]
[X] Cannot delete file "xxx.tar-8f1f.ffs_tmp"
ENOENT: No such file or directory [unlink]
I tried to manually download them, and google takes a lot of time (40 secs aprox) to "Searching for virus..." but then they download fine. I think the problem is that FFS gives up on copying at 10 secs but google takes longer to allow download.
In the next version of FFS I'd like to have a setting to modify the file copying timeout (those 10 secs in the error message, which is different from the "access timeout" setting in the cloud icon which I already tried) so I can check my assumptions.
Thank you.
Operation too slow error with Google Drive
There is only one timeout used for all cases. Setting "access timout" to 40 seconds instead of 10 should work.
I already tried that and didn't work, but for some reason I tried again and now it does work, idk what happened. Anyway, thank you.
Still, it would be nice to bypass Google Drive's virus scan (if possible). How do I suggest this to the devs?
How is setting "access timeout" I not fine itThere is only one timeout used for all cases. Setting "access timout" to 40 seconds instead of 10 should work. Zenju, 25 Jul 2024, 13:37
Click the cloud icon next to the location box, then look at the right sideHow is setting "access timeout" I not fine it artodeus, 23 Sep 2024, 06:02There is only one timeout used for all cases. Setting "access timout" to 40 seconds instead of 10 should work. Zenju, 25 Jul 2024, 13:37
