Include/Exclude .hidden files/folders?
jsau
Hi there,
I have tried to filter by .hidden files/folders but FFS doesn't seem to make any diference.
I have the c:\Users\ -> mirroring through to \\backup\Users\ folders
but when I add any of these for hidden folders to exclude, none work (they all get copied anyhow)
...etc.....
I don't even want the hidden folder name copied over so \*\.*\* will not do....
Any suggestions? (ps this has nothing to do with hidden folders/files on the File System, its for FFS only)
therube
Try:
. matches a literal dot
* matches zero or more characters
So things like
.out
.metadata-v2
.startup-incomplete
.padding
.usage
should all be excluded.
(And I take it that you're wanting to exclude "filenames" that start with a (.), rather then files that have the hidden attribute set.)
