Results Dialog box doesn't stay up after it's shown
phrab
I have FreeFileSync 3.7 [Donation Edition].
Instead of the results dialog being shown & staying up, it now pops up & then disappears. Is there a way to keep it up until I dismiss it, because that's the way it used to work?
Thank you.
Is your configuration saved as a .ffs_batch file? If so, try "Save As" and make sure "Auto-Close" isn't checked
phrab
No, it's not saved as a batch file (those are attended, right?). I have 2 batch files that run minimized & autoclose, but several that aren't batch files. However, the result dialog box closes & doesn't make a sound, even though one is set for comparison.
If I choose, Save As..., this dialog box opens: (although I don't want an unattended batch file, so I haven't saved it as a batch.
Also, this is what options I have chosen:
The latest screenshot shows "3 dialogs hidden". One of them is likely the results dialog.
phrab
Thank you Zenju for Post 7138!! You're right. Of the 3 dialogs hidden, I had to change the 2nd from the top to this:
Now everything works the way I wanted & the sound is back when synchronization finishes.
Just to be proper, that was Zenju who provided that answer! He is the dev
phrab
The latest screenshot shows "3 dialogs hidden". One of them is likely the results dialog. Zenju, 07 Aug 2024, 10:59
Thank you!! You're absolutely right & now everything works.
