RealTimeSync Can't Find Batch File
knowbuddy
I had to move my Documents Folder to my D drive from my see drive. Now whenever I reboot my pc my RealTimeSync keeps looking for the old batch files in the C drive and gives me an error message. I have tried completely uninstalling FreeFileSync and reinstalling with no success. How do I correct this??
Open the GUI of RealTimeSync (RTS), and then open the faulty saved RTS configuration (*.ffs_real).
In the Command Line field of the GUI, you can then change the path to the specified *.fss_batch file to the correct one, and save the RTS sync configuration again.
